Rear Drive pulley Question
Is there a left hand and right hand drive pulley?
I have a 98 Softail - Installing a 250 wide tire swing arm kit and need a 20 mm belt and pulley - Left hand drive
Using stock front drive pulley - 132 tooth 20 mm belt - 65 or 66 tooth rear pulley
Any input is appreciated
Thank you
Thank you
Thanks for the reply
I wasn't sure if the pulleys were machined different for left and right hand drive. My problem right now is the belt and pulley combo I was told to use 70 tooth pulley with a 132 tooth belt - the axle is to short to fit the swing arm. I figure going to a 65 or 66 tooth pulley will allow the axle to fit properly for belt adjustment. so here's another question. Ratio - 5 speed trans 132 tooth belt 66 tooth pulley will most likely slow the bike down a bit. I have a spacer kit so once my belt and pulley problem is solved i should be able to set the proper clearance. thanks for the input.
eighteight (04-26-2020)
