Ticking sound?
Ticking sound?
Greetings,
I've recently discovered a "ticking" sound whenever the clutch is engaged. If I push the lever and disengage the clutch the ticking sound is gone.
The frequency of the "ticking" increases with rpms and to me it sounds more that it comes from the left side/primary.
Worth to mention is that a HD dealer (whom I've reason to believe they didn't do a good job) switched start engine and compensator on it last year. Some suggestions after having read on forums is that a loose compensator screw can make this sound? Or any other suggestions?
The motorcycle is a Night Train 08.
Ridetothehill
11-16-2021 05:43 PM
