Screamin Eagle Big Twin Compensator
#121
couldn't get the rotor off
Hey everyone, I went to install my new SE compensator and couldn't get the old rotor off because the inner primary was in the way. I started on friday afternoon after making a primary locking tool from 1/4 X 1 1/2 flat bar. Everything went well until I tried to get the old rotor off. I removed the clutch and old comp then, all of the inner primay bolts. I was able to pull the inner primary cover out and down and get the rotor almost off but never all the way. It looks like I will have to pull the inner primary all the way off and that is going to be a PITA. I think I will have to pull the starter and that requires removing the oil tank ( as far as I can tell ). Does anyone have any suggestions? (I really don't want to grind down the inside of the inner primary ) What really sucked was that I was going on a ride the next day early and ended up putting it back together without changing the comp because I didn't have time to pull the starter.
Respects,
Spanky
Respects,
Spanky
#123
#124
Respects,
Spanky
Respects,
Spanky
#125
#126
#127
Don't hold your breath!
Sounds kind of scary; but really no problem.
Here is the problem for us now .......... I talked to a very nice (knowledgeable) gal up at SOHB, and she said that the Hydraulic Chain Tension Adjusters for the newer ('07-'09) bikes won't really be ready until April or May!
I guess I will just wait to see; and then buy one for the late Spring "project".
good luck,
redrazor
#129
I used a die grinder with a carbide burr made for cutting aluminum , I wrapped the rotor and clutch with rags and in 5 minutes I removed all the ridge that was cast in the inner primary.You don't need that extra ridge.You will notice that the new rotor is bigger in diameter. so grind the ridge flush.Also the Belleville spring washers are way too loose on the rotor and hub.There is .043" clearance on the rotor boss and .028" on the splined hub.I welded four beads about .0375" long at 90 degrees to the inner bore of washers and machined them .003" larger than than the rotor boss and hub diameter.If you install them loose they will rest eccentric and create an imbalance.I calculated that if they were all to one side, there would be a .12 ounce imbalance which amounts to 8.2 lbs of centrifugal force at 4000 rpm and .84 lbs at 2000rpm.Enough to make my dentures rattle, not as much as the bad crank I had HD replace at 2000 miles on my 2007 FLHX.
#130
It would appear you cannot take something out of a box and use it as is I have the same disease.
Ron
