How much oil in the primary case?
I changed the oil in my 06 Ultra for the first time a few days ago (previously done by dealer). Everything went ok except I may have put too much oil (Syn 3) in the primary case. Owners manual said 32 oz (1 quart) but I was thinking I had read somewhere to keep filling until the oil runs out the big hole under the derby cover (while the bike is sitting upright). After about a quart and a third, I began thinking that sure is a lot of oil.
So I cut it off at 1 1/3 quarts. Is that too much? What would be the harm? Should I drain off the excess. I haven't run it since changing the oil other than long enough to fill the oil filter.
Thanks,
Gary in Virginia
Thanks,
Gary in Virginia
Thanks,
Gary in Virginia
Thanks,
Gary in Virginia
Thanks everyone for your feedback. By "spring" I presume you mean the flat spring (about 4-5" in diameter) pressed against the smooth fly-wheel looking thing (the clutch diaphram?)?
If I am correct, then I should fill to the bottom edge of the spring with the bike resting on the jiffy stand. Is that right?
Gary in Virginia
Gary in Virginia
I fill to the bottom of the spring and have had no issues.
