Removing transmission sprocket nut - use torch?
Holy crap. OK, I got the special 2 1/4" socket from George's Garage in the mail today. Wow, fast shipping! I ran out to the garage and put on the little pilot piece and then the big socket. Attached my breaker bar to it and had my wife hold down really hard on the rear brake. I checked the service manual and it says this is a right-handed thread. So I tried VERY HARD to turn the nut counter-clockwise. Went so far as to STAND on the end of the breaker bar (I weigh about 185) and bounce up and down on it. I wasn't sure if my wife holding down on the brake was going to be enough but it did hold the sprocket stationary. That damn nut will not BUDGE. The service manual says to use RED LOCTITE when putting the nut back on... 35 lb-ft. I guess it's thread-locking compound that's keeping me from getting that nut off so far. Is heat the answer here? Hit the nut with a torch for 15-20 seconds or so and try again? That thing thinks that it is not coming off. Would using a torch be ok here? Or am I gonna mess something up if I heat the nut up? Any other ideas besides "use a longer cheater bar?" Thanks...
edit note: I just edited this post on 5/30/2010 to indicate the socket is 2 1/4" and NOT 2.5" like I originally stated.
If the manual says 35 ft.lb. for the nut then you are looking in the wrong place in the manual...You may have it confused with the clutch hub nut.
Not sure what you are working on...give us a hint.
Not sure about the six speed boxes, but if you are working on a five speed, I bet you have the nut good and tight now...
I agree with you about Georges Garage fast shipping, when you hit the enter button on the computer, you hear the box hit the driveway outside the garage...
Last edited by Dan89FLSTC; 07-25-2009 at 05:54 PM. Reason: I`m an old fart, I forget stuff...
That bolt is righty loosey,lefty tighty check out this link here
http://www.kenandjudy.us/Motorcycles...oralPage18.htm
Interesting responses... I'm talking about the transmission sprocket on a 6-speed '09 Street Bob. Page 5-18 of my service manual covers removal of the transmission sprocket. It shows using the special tool I just ordered. It says :
5. Remove transmission sprocket
a. See figure 5-39. Remove 2 screws and lockplate. (I looked at the figure and it looks exactly like what I see on my bike. I removed the 2 screws and the lockplate.)
b. See figure 5-40. Secure sprocket using FINAL DRIVE SPROCKET LOCKING TOOL. ...
NOTE: Sprocket nut has a right-hand thread. (it actually has right-hand in bold).
c. Install PILOT (this came with the special tool) on mainshaft.
d. Remove the sprocket nut using MAINSHAFT LOCKNUT WRENCH.
So my service manual CLEARLY STATES that this is a right-hand thread. This is going to **** ME OFF if I find out the service manual is wrong. Can someone else look in the service manual and verify what I'm saying is true? The link that was given above shows someone removing the nut on a '02 Ultra Classic. My bike is an '09 Dyna Street Bob. I'm REALLY WONDERING about whether or not this is right or left-hand thread but my service manual DOES say right hand and I'm not confusing this with the clutch hub nut. My clutch hub is on the floor and the inner primary is already off. Thanks for any further input.
<---- sarcasm
NOTES:
The transmission sprocket nut has right-hand threads. Turn the nut clockwise to install on the main drive gear. (it has right-hand and clockwise both in bold text)
...skip down to step 5:
5. Using MAINSHAFT LOCKNUT WRENCH, tighten sprocket nut to 35 ft-lbs (47.5Nm) initial torque.
6. Loosen sprocket nut to remove initial torque.
7. Tighten sprocket nut to 35 ftp-lbs (47.5) Nm.
So since it's telling me to use 35 ft-lbs for reinstallation, I assumed that meant 35 lb-ft was what was used to initially install it, which is why I said I figured it was the thread-locking compound that was keeping me from being able to remove the nut so far. I'm reading the manual, guys, and I'm reading it carefully.
EDIT: I'm also NOT READING IT COMPLETELY, APPARENTLY. Further step down (which I haven't read until just now talks about turning the transmission sprocket nut an additional 35-45 degrees. Doesn't say what torque setting that will make me hit eventually but it will obviously be more than 35 lb-ft. MY MISTAKE. I am still VERY INTERESTED in two things here, though: Right or left-hand thread, and is it ok to use a torch for sure on the nut.
