Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I have a 2005 Ultra Classic. When I shift the bike in neutral the dash light does not come right on and the radio gets all static. After a couple of seconds the light comes on. Also when shifting betwen 1 and 2 the radio gets static when the dash light does not come on. The dash light comes on but after a few seconds. Any thoughts what is wrong?
I would check your neutral indicator switch as well as your speed sensor switch, both being located on top of the tranny. I would pull the speed sensor switch and clean the shavings off of it and replace the o-ring and reinstall. Then I'd check/replace the neutral indicator switch.
