Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I have 01 E-Glide Classic. I have 24oz of tranny fluid in tranny. Tranny fluid has begun leaking out of the tranny breather tube while machine is running. Anybody know why this would be happening?
thanks
check your fluid level again. It may be too full or you may be mistaking this for a leaking transmission main shaft seal or inner primary bearing seal. check it out.
And if you mean that you added 24 oz, then yes it is too full. 20-24, with 24 being dry new box, usually takes 20-22 with just a change. Check level bike, dont screw in the plug, it just sits on the bottom thread.
