I changed my tranny fluid and went for a ride. Next day I checked Tranny fluid and it was 8 oz low. Then checked Pri fluid and it was 8 oz high. Anybody know of this and what is the fix?Thanks.
Just moved down from the northern wasteland this past October.
So I changed my tranny and primary fluids again and made sure they were proper level. Going run out about 1/2 tank petrol and check the levels again. There was no clogged vents.
Went for a little run after fluid change and I sure luv this 111.
