Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch cable seems "stretched out" after Clutch adjustment.
Old Mar 25, 2012 | 04:04 PM
tbom4000's Avatar
tbom4000
Stage II
Default Clutch cable seems "stretched out" after Clutch adjustment.
Hello,
I have been lurking on this forum for sometime now and have learned at a lot and now I need your help. I have messed something up during a Clutch adjustment. Since I was changing my primary oil it seemed like a good time to do a proper clutch adjustment. I followed the directions in my service manual and all seemed well. Except and I don't know if this matters, but when I turned the lock nut on the clutch adjuster screw the whole clutch assembly would turn with it. Also when went to adjust the free play in the cable I had to back the cable adjuster farther, almost its full travel. Did a short test drive it all function fine except the lever could only be pulled back about 3/4 of the way instead of all the to the grip.
Today I figured I would try again and see if I could it perfect. Each time I pulled the lever I seemed introduce more slack. Now I am at the point where I think I messed something up. The cable when it has the adjuster nut back all the way to point its actully off it still has a ton of free play the the lever wont even pull the clutch. When it could engaged I was dumb and squeezed the lever kinda hard to get it to touch the grip. Thats when I think truly broke it.
So what did I break? I hope this is a simple fix.
Please let me know what other information you need from me.
Old Apr 19, 2021 | 09:30 PM
0003's Avatar
0003
Came across this randomly... really curious what he might have done
Old Apr 20, 2021 | 08:29 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Not likely he is going to tell us, since he has not been on the forum in 9 years....
Old Apr 20, 2021 | 08:45 AM
0003's Avatar
0003
Funny guy. Nobody replied back then either... again I assumed someone might have known the answer but this was just lost in the mix. I still get random responses from forums years ago.
Old Apr 20, 2021 | 11:48 AM
Max Headflow's Avatar
Max Headflow
OP screwed the adjuster in too far.
Old Apr 20, 2021 | 05:58 PM
0003's Avatar
0003
Couldn't happen from cable adjusted too ar out eh?
Old Apr 20, 2021 | 06:08 PM
Max Headflow
My mistake, clutch adjuster not screwed in far enough..
galtjunk
26
Jul 29, 2019 04:21 AM
peepa
General Topics/Tech Tips
16
Oct 1, 2016 05:36 PM
jamala00
Aug 30, 2012 03:25 PM
sioux565
Jul 17, 2011 05:27 PM
VARDR
Mar 26, 2009 08:37 PM
