Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
1972 Shortster shifting
Old 04-27-2012, 10:45 PM
HotRod HD99's Avatar
HotRod HD99
HotRod HD99 is offline
Stage III
Default 1972 Shortster shifting
Hello,
I rebuilt a 1973 Harley Aermacchi shortster. I starts and runs great, but it wants to pop out of gear. I have a service manual for it and know the shifter arm is adjusted properly. The bike was not running when I purchased it, so I'm not sure if this was a problem before or not. When I split the cases, I made sure I put it back together the exact same way it came apart. The gears and dogs looked good. Any suggestions before I split the motor again?
Thanks
Andy
Old 04-28-2012, 09:43 AM
mrlexus's Avatar
mrlexus
mrlexus is offline
When you split the cases did you make sure you didn't lose any of the gear set spacer shims? They often stick inside the case. Bad news is you will probably need to split the case again. There is a section in the service manual for checking side play, make sure you do it by the book. When you put it back together, did you use an original gasket or rtv? I have a couple of these little bikes, and if you don't shift them with some force, they will tend to pop out of gear. My gf has the issue when riding my z90, but I never do.
Is this a 72 or 73? The 73+ are 90cc, the 72 is a totally different bike and 65cc.
Old 05-01-2012, 07:27 PM
HotRod HD99
Stage III
It is a 72 m65 Shortster. I was thinking I was going to have to split the cases, but was going someone might have a different suggestion. Thanks!
PS. New gasket
Old 01-20-2019, 09:30 PM
TGE's Avatar
TGE
TGE is offline
1st Gear
Good evening HotRod,
I have come into ownership of a shortster 65cc and am in need of a service manual but cant seem to find one, can you help?
Old 01-29-2019, 05:31 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Red face
Unfortunately HotRod posted this back in 2012 and only ever posted three times on HDF in that year, so it is unlikely you will get a reply. I recommend you start a fresh thread. Your local dealer may be able to supply a new FSM, it is certainly worth asking.
Old 01-29-2019, 09:44 AM
bustert's Avatar
bustert
bustert is offline
mr. t
i do not know if you have enough service time on the forum to be able to PM.
i think i may be able to help on the fsm,
click on my handle and see if pm is allowed, if so, send an address, do not post here on the forum unless you want the world to know.
if not, post back and i will see if i can get a link.
just checked your handle, looks like i can pm to you, so if i have the info, i'll send you a pm.
Old 01-29-2019, 03:06 PM
bustert's Avatar
bustert
bustert is offline
i have the fsm and parts book also.
Wcm71
Ironhead
07-20-2015 05:36 AM
DISTURBEDRYAN
07-08-2014 06:52 PM
MB1953
08-11-2013 08:30 AM
baneban13
07-20-2013 09:32 AM
wildchildcustoms
07-16-2010 10:30 AM
Quick Reply: 1972 Shortster shifting
