hydraulic clutch
hydraulic clutch
I am putting 16 inch apes on a 2003C CVO Road King,
some say that I will have problems with the hydraulic clutch, maybe the reservoir is too far from the clutch, dealer claims that I may need to go to an acuator or mechanical cable. This does not seem right if the line is made longer and proper bleeding have been done. Has anyone had any problem with a mod like this or advice?
I installed a A.R.T hydro clutch unit on my 4 speed Shovelhead. I have 16" apes also. The hydraulic line I bought was about 40". The hydro clutch works great. even with the lengthy line.
However, I can't speak for stock HD set-ups but theoretically if the line reaches the master cylinder it should work.
RFG7680
2014-2023 Touring Models
06-15-2016 08:26 PM
