help with clutch hub installation
Ok, this is the first time I'm doing this...
my inner clutch hub is broken, and I just ordered a new one..
I'm starting to tear down the old one, I left the inner clutch hub nut and it came off with the outer hub after pulling them with a "special and cheap" puller I made
now, when I will put them togheter again into their place.. shell I use some special tool too, or will I just lock and thight the inner clutch hub nut?? Cause I tried and it is terribly hard, and it looks like is a long long way by doing this...
Is this the right way to put outer and inner clutch hub, in their place, again?
Thanks for help!!
And sorry for my american, I'll try to do better if I wasn't clear
By the way, I'm working on a 1988 FLHTC
Thanks for help!!
