Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I have a 2007 Road Glide. How frequently must the Primary Chain Tension be checked and or adjusted? Same question for the final drive belt. Thanks, 07 Gliderider
Your 07 came with an auto adjuster for the primary. However, the stock unit has been known to not do what it was supposed to. I'd replace with a Hayden or another brand, but that's my opinion. The drive belt I check every rear tire change. Can do it more frequent if you'd like.
