Must-Have Tools for Touring
#31
#32
Received 47,791 Likes
Yep ... I've only been in 46 of the 50 states ... call me a rookie too if it makes you feel more superior ... What can't get fixed with the phone and or credit card ? I should state that I've made my living as an ASE mechanic for mos of my life .
cacomly (04-16-2018)
#33
Small air compressor that plugs into the cigarette lighter tire slime tire plugs and a good set a tools plus most important two tie Downs and a long piece of rope ,fyi The shift linkage on touring bikes always fall apart Another thing that's always a good idea to carry kickstand return Spring
#34
I carry the slime tire compressor and slime though I have tubes so not sure the slime is useful, a portable battery jumper, spare FOB battery, leatherman, Allen wrenches specific to the bike, stubby screw driver with bits specific to the bike, air shock pump, electrical tape, zip ties, fuses, mini vise grip, a few wrenches specific to the bike, microfiber rag, tire pressure gauge, two koozies and I believe a blade. I'm sure I'm forgetting something.
One thing I read on this forum is that any tool you carry should be a tool that will actually work for the desired repair when stranded. In our garages we have tools and supplies but on the road, though you have a wrench, will that wrench fit in those tight spaces and such? It got me to re-evaluate the tools I carry and test to see if they will actually do what I want them to in a pinch.
#35
However if a rider is one who gets off the beaten path and finds there are no cell towers in the area having a good set of tools helps even if the rider has no idea how to use them as someone who does may stop and not have theirs with them.
I carry a fair sized set of tools that can do most things one would expect happen on a long trip. During the 2015 and 2017 Iron Butt Rallies I added to it to be able to do almost anything. That came in handy when I lost my charging system in AZ and ended up having to replace my stator in a friends garage overnight on July 3/4 using the tools I had with me. The only thing I was missing was a 4 ft piece of pipe to break loose the nut holding my rotor in place (compensator nut for non Sporties) and the 1 3/8 socket which I had put down when packing as I had a brand new stator and did not think I'd have to replace it.
How did my cell phone help? I was able to call my buddy and make arrangements to get to his house and have him pick up the new stator, it allowed me to call a friend who is the parts manager for one of my local HD dealers and have him track down where all of the stators and regulators were in AZ so I could get them. Without my cell phone I would have been SOL and relegated to using a ton of quarters in pay phones (if you can find one) or racking up a huge bill using a phone in a hotel room
#36
I was going back through this thread and the thought came to me about my first trip to Sturgis for the 49th in 1989.
Even then I couldn't believe how many bikes (and bikers) were sitting on the side of the road, working on bikes or loading bikes into trailers.
The following year, we went again and it was like a difference between daylight and dark!
I don't know if more people had newer bikes or if perhaps they had taken the time to make sure their bikes were "roadworthy" or what but there was (or at least I thought) a very visible difference in the number of bikes sitting beside the road.
#37
This is what I packed in tools for Alaska in 09. Along with a HOG membership. Never used any of it but it was a small kit that didn't take up much room.
Road Repair Tools: Harley Davidson (SAE)
TOOLS:
Socket Set 3/8 (6pt) drive: ¼ - 7/8
6” extension
Spark plug socket 5/8
3/8 drive to ¼, Reducer (for smaller ¼ inch sockets)
3/8 Universal
3/8 drive Hex sockets, set 7
3/8 drive Torx sockets, set 8
Wrenches: 3/8 – ¾ (Gear Wrench)
+10mm combination wrench (battery)
Screwdriver, ¼ bit type (w/small Torx)
10” Adjustable wrench (for larger then 7/8 sockets)
Small hex key set: knife type, Ekland
Small Vice-Grip
Long Nose pliers with side cutter
Air gauge
Lock-Tite, Small Red
DC Air Pump
Tubeless tire patch plugs
Fuel Siphon hose & Container
Flashlight
Motorcycle Jumper cables, Yuasa
PARTS:
Spark plugs
Fuses, small type, 3 each: 10A, 15A, 20A
Fuse, Main, 1 each: LARGE 40A
Bulbs: Tail & Head Lamp
Electrical tape
6’ wire
Zip Ties
Rags
50’ Nylon Rope – possible towing
Belt repair/Spare (never had one go, got pretty tore up in Canada one time but drove 6k more miles with that bad belt)
Clutch cable repair kit
Duct Tape
Everything listed above will fit inside the Military Canvas/Nylon tool bag and will take up little room in your saddle bag.
If these tools aren't enough use your HOG membership!
NOW FOR MY FINAL THOUGHTS ABOUT TOOLS FOR TOURING:
1: KEEP YOUR HOG MEMBERSHIP CURRENT.
2: I'VE NEVER TOURED WITH A BIKE OLDER THAT 10 YEARS OLD.
3: I HAVE STOPPED CARRYING THESE TOOLS AROUND OTHER THAN THE CHEAP HARLEY FACTORY CLOTH TOOL KIT. (oh, and the Yuasa jumper cables, I keep leaving my ignition on...)
NOTE:
THAT'S WHY I RIDE A HARLEY - IT'S RELIABLE! (and you can't swing a dead cat without hitting a HD dealer)
#38
#39
Now, if you get remote, like I do, a really good tool is a Delorme InReach Satelite device. They can be charged on your bike, and you can use your Cell phone to text for help. I never used mine for an emergency, but did test it when I had no Cell service by texting people. They are not cheap, and there is a monthly service fee. But it could save your ***. Instead of abandoning your bike, you could get someone to call HOG for you, HOG texts you, and then by texting they sort out where you are, and who to dispatch to come fetch.
I was convinced by a couple motorcycle buddies who swear by it, after each of them were left stranded...once...never again.
I got the Recreation annual plan, since I plan to carry it with me all the time, whether riding, driving, etc.
#40
You picture has given me valuable idea thst I never thought about for the bike, the toilet paper...that is genius and I'll be adding a partial roll to my arsenal. I carry sunscreen too and i never get sunburned but I do make it a point to laugh at everyone who laughed at me the day before
