Sturgis- Cell coverage
Old 06-26-2018, 09:58 AM
From_Behind's Avatar
From_Behind
From_Behind is offline
Sprint definitely has the worst coverage in the area, and Verizon the best. Sprint is painfully bad. It's kinda nice - my phone doesn't ring much. 😁
Old 06-26-2018, 10:01 AM
From_Behind
Originally Posted by rnl_1200C
it might depend on the phone. I have Sprint with a Galaxy S8+ and the coverage map shows good roaming coverage. I am staying in Rapid City, and the map shows 4G service. I guess I'll find out next month.
You're golden in Rapid City. Out in the hills, good luck. But, no issues at all in Rapid.
rnl_1200C (06-26-2018)
Old 06-26-2018, 10:02 AM
From_Behind
Originally Posted by ROUNDHEAD
Listen, if you travel at all you need Verizon. Its a crap shoot with the others including AT$t
I travel more than the average bear on these forums (or anywhere on the planet, really), and I have zero issues with Sprint. There are only about 4 places in the US that I've had issues. It might not work well in Death Valley, but I don't go there much these days.
Old 07-02-2018, 09:41 AM
Rock&Roll Rudy's Avatar
Rock&Roll Rudy
Rock&Roll Rudy is offline
Stage IV
Originally Posted by Bluraven
Just putting this out there for those traveling to Sturgis and the surrounding area.
Sprint's associated secondary carriers such as Boost Mobile do not have cell/data coverage within the area.
Also, text is hit and miss.
So if you're traveling in the area make sure you plan ahead.
We travel to the Black Hills every summer and switched to Boost Mobile last fall not realizing there's no coverage in SD, WY, MT or ND.
We'll be switching carriers when we get back home.
Just rode 6,000 miles out west from Michigan. Camped in the Black hills using Verizon. No problems!! Found that to be true most anywhere I went. S.D, UT, WYO, CO,. Some iffy spots out in the Great Plains of Wyoming but then again there is nothing out THERE for miles!!
Old 07-02-2018, 10:44 AM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,448 Likes on 11,204 Posts
It doesn’t matter if a carrier has coverage. When 300,000 plus users show up, all the networks will be saturated and you won’t be able to make/take a call. We found that if we wanted to make a call, early in the AM, worked best.
Old 07-11-2018, 12:01 AM
F150HD's Avatar
F150HD
F150HD is offline
Received 1,273 Likes on 839 Posts
Great info, and one more reason for me to dump Sprint. Coverage keeps getting worse and worse....heading towards Verizon.
Bagged Out
Pacific
07-30-2017 12:37 PM
scumBAGGER
Road Trips
11
07-14-2015 06:44 AM
hogowner69
07-07-2015 08:15 AM
yzergod
Road Trips
13
08-04-2013 06:30 PM
Bluesfan
Road Trips
03-12-2011 09:36 AM
Quick Reply: Sturgis- Cell coverage
