I have a 2015 FLHTKSE and an going to add the saddle bag lights. I was going to use 67800451. Can someone tell me if the brake lights will light on the bags ? On this bike the Tour Pac lights do not light with the brake.I want to add these lights because the lights for the brake are not enough.I read somewhere there has been a problem and they had to use the non CVO kit. Thanks
I have a 2016 FLHTKSE with these lights Part# 67800451A on it. Very bright and compliments the back of the bike. they are running, brake and turn signals. My light bar on the bike is also running, brake, and turn signals. I would think yours should be too.
I should have been a little clearer. On my 2015 the Tourpac brake lights only light in the middle of the bar. The turn on the Tourpac do not light on the brake. Turn only light on turn and running. Thats why I was adding the bag lights. My 14 Limited was different. Can you check to see if yours works the same.
I went to my dealer because the outside lights on my TP on the 2015 CVO Limited only lit on the directional and they did not think it was right but after they checked it out they said it was working right. My 2014 worked brake on the outside of the TP. I have checked other 2015 CVO Limited and they do not have brake lights on the outside of the TP.This is why I want to add saddle bag lights.
my 2015 CVO Limited does exactly like yours, the TP signal lights only turn on as running lights or signal, not brake. I added the Electra Glo LED to the saddle bags and they work as running/brake/signal. Easy add on.
Can you tell me what lights did you install ? 67800451 ?
