Dealer Calls me and says warranty is void
You said "extended warranty", but I assume you mean Extended Service Plan.
Basically, they're trying to screw you. Ask for a written estimate for the work that needs to be done. If there's nothing that is directly related to the state of tune of the bike, meaning fuel and ignition, then get a lawyer.
cajunlowrider (04-16-2017)
Received 1,934 Likes
Back to the topic.
if you left your power vision and target tune on your bike when it went in for service you have a problem. if you unhooked your narrow band sensors and they were not hooked up when the bike went in for service you have a problem. if you did not restore your STOCK map back to your ECM before it went in for service you have a problem.
the mere presence of a alterning device for fuel, timing or other basic emission controls provides enough evidence to void your ESP.
they take pictures of everything, the inspector is not even allowed to talk to you when he is doing the inspection nor is he allowed to give you his report. All is sent back to headquarters and his observatios,pictures and other electronic evidence is used to make a determination.
this determination is not made by the inspector alone.
once a repair is authorized only the work authorized can be completed under ESP. if you want more, its your dime.
i had this experience and it sucks. be nice, be thoughtful and be diligent. persistence pays off vs being a bad ***.
i hope it works out for you. mine worked out because of 3 random but connected events. one, i took the power vision off the bike, 2 my 02 sensors were hooked up and 3 i restored the stock tune back to the ECM on advice if the technician who was to work on the bike. i was questioned by the inspector through the dealer if it had a tuning device installed, i did not answer the question, i asked "what is that?" appearing ignorant is better than being smart. last, my failure was 100% mechanical, with a broken lifter. i could point and say, that dont look right.
ps, if they do void your coverage for esp, it is specific. engine, trans, etc. its not for the entire bike.
my cvo has its coverage voided for the engine, ( installed 120R) but everything else is still covered, including wheel/tire.
Scudda (04-14-2017)
Good luck. My bike had the extended warranty. Long about 15K, there was ticking noise from the primary. They went in and $50 later told me the compensator had got loose. Abut 25K, same spill and $50. At 30, the same thing. I got tired of the $50 and pulled it down. All they had been doing was tightening it down. What truly was the problem was the alternator rotor spline was gone and it would slip wearing an area in the soft metal. This would let the sprocket move over and the chain would nip and make the tick. Bolt was still tight with loctite.
I took the parts in figuring they would appreciate me doing all the work.? Ha. First thing out of their mouths was they were voiding the warranty. I did a little fussing and ended up in the owner's office. I dropped the rotor down on her desk and my last two repair bills. She told me it was too late to save the warrant since the mother ship now knew but that the dealership would give me 10% off parts on it.
I can see there point with some cases. The mother ship is catching broken modified Harleys that their dealers do making money. My bike was stock and they screw me three times. So good luck.
Unfortunately I think we are going to be hearing this more & more.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
HD better cut that sh*t out or they'll cut their own throat. A lot of people buy new HDs for the "piece of mind" warranty. If HD does everything they can to deny warranty claims there's no incentive for many customers to buy new. Let's face it, one Harley is basically just like the other, brand new or 15 years old; it's an overweight, under powered machine with crap suspension. A clean low miles used bike will do everything a new M8 will, except for linking your text messages to your "infotainment" screen (don't get me started on that one).
My point is, one of the hallmarks of HDs marketing is "make it your own". But if making it your own puts you "on your own" more people who are mechanically inclined (or are willing to learn) are going to buy used for a fraction of the price. The US is lousy with low mile, well cared for Harleys. Some may even opt to buy another brand that doesn't require modifications out of the showroom that can potentially render the warranty useless. That could cause a serious dip in sales.
I don't know if I'm right or not; only time will tell. I love my Harleys but I could give a tinker's dam if HD stays in business. I can Craigslist or after market my way into anything I need for the ones parked in my garage for as long as I live.
hvacgaspiping (04-17-2017)
