-1" Kick Stands for Lowered Bikes.
Going to lower my 2018 CVO Limited 1" front and back. That means I need to change my kick stand or the bike will stand way too upright. Apparently HD does not make one.
Pingel makes a nice one but at $200 plus it is kind of spendy. I called up Arlen Ness to see if their's fits and they told me the following. "It fits, but the rubber bump stop misses and the metal of the stand touches the crank case." I am pretty sure that means no.
So are any of you running a shortened jiffy stand for lowered bikes? What type is it and how do you like it?
Inquiring minds want to know....
50000149 jiffy stand, black. found on 2018 cvo limited, street glide, and road glide
50075-07A jiffy stand, chrome. found on most everything else
50000083 jiffy stand, chrome. found on the low models.
I lowered mine 1" front and back. Yes you can use the stock jiffy stand when it's on a flat level surface. However when it's not, it's a PITA
I bought an Arlen Ness -1" jiffy stand. Much easier parking anywhere. I did have to adjust the rubber stop, bend it some. Otherwise the shoe of the jiffy stand will hit the bottom of the primary cover.
I have a mid frame mounted short kick stand on my Bad Boy. I don't remember the brand (I installed it 20 years ago), but it works well. I had to drill and tap the frame, but I like it better than the forward stand on a low bike. Maybe something to look at?
Edit: The rear of the bike is currently 2 1/2" lower than it is in this pic (The front has a 2 1/2" lowering kit in the pic) and the stand works well.
