Need help with adjustable clutch and brake levers
Good afternoon everyone,
I have a 2007 Screaming Eagle Road King CVO FLHRSE3. This bike seems to be the red headed step child of HD bikes. I've not been able to find adjustable clutch and brake hand controls. I have email correspondence with Oberon Performance who explained they had nothing but trouble with CVO's in general and my year/model specifically. I've drawn blanks searching the 'net for other manufacturers. What makes my bike different than other model RK's is Harley used a hydraulic clutch on the CVO RK while standard models the clutch is cable actuated. Has any body else experienced this? Can anyone point to a supplier or manufacturer who has the correct hand levers? Thanks for your help.
I just ran into this exact problem with my 2013 CVO FLHTCUSE8. All the hydraulic clutch levers of that era on the touring models are the same. You have to order the hydraulic clutch version. My buddy's 2014 Ultra Limited has the same lever as my 2013 even though the book says that the touring models had cable clutches. The CVO's had the hydraulic units. It's the same design as the 2014 clutch levers. I was mistakenly sold the wrong kit at an event recently and it had the cable clutch lever in it. I like the adjustable FLO Motorsports brake lever and I will probably just order the correct kit from them and gift this to someone who wants it. You can't just buy the single lever from them.
Fitment For Hydraulic
2014 - 2016 Touring Models
Part Number HD-808
According to the diagram on Ronnie's parts site your lever is the roller type. Here's the link. Ronnie's Harley-Davidson | CLUTCH LEVER ASSEMBLY (onlinemicrofiche.com)
If your lever has the roller in it then this kit will work with your hydraulic clutch.
Part Number HD-808
Kevin Robinson
May 29, 2013 02:18 AM
