CVO Handlebars different?
Old Jun 12, 2025 | 05:49 AM
BigMike's Avatar
BigMike
Default CVO Handlebars different?
I'm looking for 10" handlebars for my '15 CVO Limited. I found some off-brand bars but they say "does not fit SE models". I looked up the part numbers on the CVO and non-CVO Limiteds and they are different part numbers. Does anyone know the difference between the two? Thanks.
Old Jun 13, 2025 | 08:07 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
My experience has been with the heated grips. On some brands not intended for heated grips they are long on the clutch side and require trimming to length. I’ve had to do that twice to get all the gaps right on the controls.
Other than that I do not believe there are any differences.
Old Sep 25, 2025 | 01:38 PM
jimsuver's Avatar
jimsuver
The bars are the same shape for the touring bikes. The CVO's have internal wiring, so there are a few extra holes that the regular bikes do not have. Your installer should be able to make most bars work for you.
Old Jan 29, 2026 | 08:04 PM
Heresolong's Avatar
Heresolong
Sorry to resurrect an old thread but I think this is good information for anybody looking. The difference is the handlebar clamp. The CVO bars don't neck down to one inch at the handlebar clamp, and so they have an inch and a quarter clamp. If you want to buy stock bars, you can easily do so, you just need to replace the clamp as well as the bars
balloo
16
Aug 21, 2021 09:11 PM
Litterbox
Jan 13, 2018 11:22 AM
elb62
2014-2024 Touring Models
Mar 10, 2016 10:14 AM
MARCUS 79
Aug 26, 2014 09:26 PM
Wghussey
Aug 14, 2014 07:46 PM
