1980 FXWG Where can you buy points/condensers?
But if you want a newer version, you could do lots worse than look at the Ultima ignition systems. They do away with the external module as electronics are much smaller these days and all the electronics fit under the points cover.
Oakleyrider (08-22-2017)
If you do have points look for Blue Streak stuff,
http://www.jpcycles.com/product/381-281
And secondly the timing advance behind the points plate is probably junk, pick up one of these don't get a the cheap one they don't last a summer.
http://www.jpcycles.com/product/381-306
You can put points and condenser and advance unit to any shovel/evo
Beg to differ, biggest issue with advance units is the pivot shaft and the hole in the weight wear out allowing the weights to open wider letting them hit the inside of the nose cone bouncing the timing all over the place.
