'O' and X-Ring Chains - Worth The $$???
I can move the drive chain on my 75 FXE laterally close to 3 inches - would seem to be an indication that a new chain is in order.
My only experience is with standard plain-jane chains, clean and oil occasionally and keep the tension right.
'O' ring chains seem to hold the promise of not requiring external oil application, so the rear rim would stay clean longer and it would seem that no grit in the chain internals would mean longer life and less stretch.
And X-ring chains promise the same but with less friction due to the shape of the seal.
Anyone had experience with a sealed drive chain? I'm wondering what reality is vs. the marketing claims.
Big believer in o-ring chain...I get the nickel plated ones..kinda look like chrome.
I run one with sprocket -brake...I never put any lube on it...wipe it down once in a while with WD-40 to clean it...after the initial stretch when you first install it...I never adjust it...chain adjustment used to be a constant thing...I would never run a "regular" chain again.
When I originally switched over to chain I went with an RK chain. Every 2-300 miles I had to adjust out the slack. Never stopped stretching. I also used a Zippers sprocket front and rear. The rear sprocket was made out of hard aluminum (I forget the grade) well that didn't hold up either. Not even 2000 miles later I had to replace both... Chain was ruined and so was the rear sprocket. Check it out..
So if your motor has some serious power get a steel sprocket. I believe the second chain I got was a D.I.D. chain. I'm out of town right now but when I get home I'll look for the receipt to id the chain... So far it's lasting and only had to adjust it once and no noise. O-ring is the way to go. Just get good chain wax and at every 500 miles, apply it hot (after a ride)... And don't get a Gold chain, it will leave a lot of gold dust on your rims...... Don't over wax the chain either because that **** is hard to clean off of the swing arm, rims and chassis...
Higher end O-ring chain the only way to go I used tsubaki when I ran chains, diamond and RK had no life. Sprocket wise you get what you pay for cheap ones you will be eating them quicker, skip the aluminium and buy US made if you can still find them. Pricey but they will last much longer, usually 2 or 3 chain to one sprocket set was the average life I'd get on them.
