S&S billet oil pump leak question
Putting the 72 back together and have a static oil leak coming from the top inside oil pump cover screw. Now I know shovels are known to leak, but this engine has been sitting for 10 months! Should there be some type of sealer on the screw threads or is there possibly a problem with the cover gasket?
Ran the engine prior to removal and the only leaks it had were from the rocker shaft end plugs. These have been fixed.
I'm stumped how oil could be leaking from an engine that has been sitting covered up on an engine stand and not run.
1Fordman (07-15-2018)
