Gasket Q
Old Sep 22, 2014 | 12:39 PM
prplglide's Avatar
prplglide
Default Gasket Q
Over the course of the last year or so, I was slowly rebuilding my 96 fxdgw. I had to rebuild the trans, oil pump and swapped out oil lines to braided.
Last week, I took if for a ride and it was leaking oil from the lower engine cases (by the crank).
I'm assuming since it sat for over a year, that the sealant between the cases dried out and is causing my leak.
Is this a fairly common problem after sitting for an extended period of time?
I would like some more info before I actually start to tear it down for engine removal.
Thanks.
Edit:
This is also posted over in general tech tips. Never got a response, so I'm trying it here.
Old Sep 22, 2014 | 12:43 PM
M1dniterider's Avatar
M1dniterider
Did you have the cases split during this rebuild?
Old Sep 22, 2014 | 12:52 PM
prplglide's Avatar
prplglide
I did not. I'm thinking that's what needs to be done now. Just wanted to get some advice first.
Old Sep 22, 2014 | 12:59 PM
M1dniterider
If you didn't have a leak there before I wouldn't think that's it. You mentioned the oil pump. I'd look there first. Rule out that oil leak being from anything you had apart first. If you rule out everything else and are absolutely sure the leak is from the seam between the case halves, check the torque on the case bolts before going that deep.
Old Sep 22, 2014 | 02:15 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
First find the source of your leak.
Clean suspected area and spray some foot powder on it then start the motor.
Source of leak will be easy to find then.
Old Sep 22, 2014 | 02:34 PM
prplglide's Avatar
prplglide
Thanks for the speedy replies!
Can't say I've ever heard of using foot powder before...if it works, why not?
Old Sep 22, 2014 | 03:46 PM
Spanners39's Avatar
Spanners39
Sealant doesn't dry out, these cases can stay leak-free for decades...do the foot powder thing and get back to us, it might just have wet-sumped and it will clear up with a good thrashing.
harleyjames123
Sep 10, 2024 12:05 PM
monchidog
EVO
15
Aug 27, 2017 05:53 AM
joewg3
Jan 5, 2015 07:16 AM
prplglide
General Topics/Tech Tips
Sep 22, 2014 12:36 PM
01 chopper
EVO
May 4, 2013 08:07 PM
