Andrews "b"
Old 10-16-2018, 06:27 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
the compression trapped is called - static
and lobe separation comes into play in this as well as lobe center - low center numbers is the low engine speed grunt
a bbc chevy race engine with a 108 cam center will blow the tires off trying to leave the line but a 110 wont
but the 108 out a corner racing will blast off the corner and down the straight out in front of a 110 even though the 110 is faster up hi in the RPMs
  #32
Old 10-17-2018, 06:10 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,816 Likes on 3,318 Posts
Originally Posted by biginchhustler
personally I like the leinweber L3S - its got gobs of torque and super bottom end scat
L3S Intake: 35/59 274 0.485 Exhaust: 63/31 274 0.485 Overlap: 66
remember leinwebers open/close numbers are .020 not .053
We're pretty much talkin stock cubes here not some over stroked Shovel... I'm sure your compression (static) is way the hell up there @59*.. Don't confuse people...
  #33
Old 10-17-2018, 11:37 AM
biginchhustler's Avatar
biginchhustler
biginchhustler is offline
can I make a suggestion? visit leinwebers cam selection site
-- http://www.leinewebercams.com/PG4_SH...4wfall2016.pdf -- look at the top -- see where it says .020? and .053??
he checks his duration @ .020 every other cam maker uses .053 -- so when you see a closing of 59 its not 59 as your thinking --
maybe YOUR confused but most of us know the difference -- the L3S is for stock 74's and stock 80's --
  #34
Old 10-17-2018, 11:45 AM
biginchhustler
like your evo in the pic --( nice bike by the way ) I have a 1984 evo-- fxrs its 10:5:1 just a 80" - I use this cam
E5S - IN .544 40/54 - 274 duration --
EX .544 68/26 -- .274 -- THE actual duration @ .53 is 242 -- Mr. Jims cam timing is what confusing to most till you understand -- ask johnjzjz -- twisted - they will show you what is ment ..
that E5S is really killer in a stock 80" evo I used the TP roller rockers
98hotrodfatboy (10-17-2018)
  #35
Old 10-17-2018, 04:47 PM
98hotrodfatboy
Even though the duration is stated at .020" the timing of the cam doesn't change...? Does it...? I mean the intake valve still starts to open@35* and close@59*... Doesn't it?
Thanks on the Evo comment.. I have a lot in that thing...
  #36
Old 10-17-2018, 05:54 PM
biginchhustler
this is my 84 fxrs - not as Purdy as yours but it does have a s*it load of hp -
the cams from leinweber are measured @ 20 going up the lobe not 53 so yeah it changes the numbers where it begins to lift and close
  #37
Old 10-17-2018, 05:58 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
we concentrate only on the advertised duration as that is the real lobe story - as its off the base circle
dwyleecoyote
Exhaust System Topics
47
01-04-2011 03:00 PM
WARG
11
01-24-2009 09:32 AM
stang2811
03-25-2008 11:37 AM
danzio
08-12-2007 05:26 PM
vthunder
04-19-2007 07:45 AM
Quick Reply: Andrews "b"
