remember leinwebers open/close numbers are .020 not .053
We're pretty much talkin stock cubes here not some over stroked Shovel... I'm sure your compression (static) is way the hell up there @59*.. Don't confuse people...
like your evo in the pic --( nice bike by the way ) I have a 1984 evo-- fxrs its 10:5:1 just a 80" - I use this cam
E5S - IN .544 40/54 - 274 duration --
EX .544 68/26 -- .274 -- THE actual duration @ .53 is 242 -- Mr. Jims cam timing is what confusing to most till you understand -- ask johnjzjz -- twisted - they will show you what is ment ..
that E5S is really killer in a stock 80" evo I used the TP roller rockers
Even though the duration is stated at .020" the timing of the cam doesn't change...? Does it...? I mean the intake valve still starts to open@35* and close@59*... Doesn't it?
Thanks on the Evo comment.. I have a lot in that thing...
Kinetic energy (KE) = ˝ mv2 we know this from our intro physics classes where m is mass and v is velocity.
E = qV gives us the energy of a charged particle where q is the charge and V is the potential difference in Volts in which the particle falls and gains energy.
This engine uses Xenon atoms that have a mass m = 2.2 x 10-25 kg and a charge of the all-familiar q of 1.6 x 10-19 coulombs, a constant that we all know and have indelibly printed into our engineering brains.
We know that 1/2mv2(Kinetic energy) = q (charge) x V (Voltage)
So, now lets calculate the speed of a Xenon atom in km/hr, assuming that the voltage grid V of the ion engine is 1,300 V:
Let KE = E and we now solve for v:
Kinetic energy = charge x Voltage
v2 = 2qV/m = 2(1.6 x 10-19coulombs)(1,300V)/(2.2 x 10-25kg) = 2.0 x 109
Taking the square root of 2.0 x 109 gives us v = 44.2 km/sec or 159,000 km/hr WOW! Thats fast.
