Andrews "b"
the guys from jersey back in the day racing hi gear fuelers, would say the ports are really to big --- but would port them on street bikes and put bigger valves with 5/16 stems to get more flow for street bikes because the guys wanted it - not because it did anything
any long duration / bigger lift - cam responds to compression - and the bigger cam you use in the combination of inches and compression the faster it will go --- its an air pump not rocket science
E = qV gives us the energy of a charged particle where q is the charge and V is the potential difference in Volts in which the particle falls and gains energy.
This engine uses Xenon atoms that have a mass m = 2.2 x 10-25 kg and a charge of the all-familiar q of 1.6 x 10-19 coulombs, a constant that we all know and have indelibly printed into our engineering brains.
We know that 1/2mv2(Kinetic energy) = q (charge) x V (Voltage)
So, now let’s calculate the speed of a Xenon atom in km/hr, assuming that the voltage grid V of the ion engine is 1,300 V:
Let KE = E and we now solve for v:
Kinetic energy = charge x Voltage
v2 = 2qV/m = 2(1.6 x 10-19coulombs)(1,300V)/(2.2 x 10-25kg) = 2.0 x 109
Taking the square root of 2.0 x 109 gives us v = 44.2 km/sec or 159,000 km/hr WOW! That’s fast.
So, now lets calculate the speed of a Xenon atom in km/hr, assuming that the voltage grid V of the ion engine is 1,300 V:
Taking the square root of 2.0 x 109 gives us v = 44.2 km/sec or 159,000 km/hr WOW! Thats fast.
They come up on the all-important torque very quickly, better throttle response, fuel economy, and smooth operation, from our experience.
Intake closing number on those 2 cams is closer to(not a match)the OEM compression ratio, than the super-late closing B grind.
Age old, bigger is better, was the thought I suppose, that had those being incorrectly installed, as even in automotive application, folks would over-cam an engine.
Many cams, many choices, we like those 2, and our clients appreciate our decisions.
One the flip-side, our 108" Shovel racer ran a Lieneweber L-6, L-7, @ 15.0 cr,(wild sound from those!) and a Andrews .660".......made more power with the Andrews, on the dyno, and the time slips backed that up.
Obsevations, and facts, from 40 years of working on HD's, and over 30 years of 65-75 hr work weeks.
Scott
That's always entertaining...almost as much fun as Talking Oil!!!!!!!!
Scott
Would those cams make a noticeable difference over the Andrews "A" cam?
In other words, I'm already running the "A", would it be worth changing it since I already have it open for other stuff anyway?
