Rear brake light switch
My brake light doesn't come on with the rear brake, did some troubleshooting and found that the rear brake light switch is bad. Checked it with an ohm meter and 0 continuity with the brakes on and the brake light comes on if you touch the two wires together.
So wanting to get this fixed today as I have a serious case of spring fever. I went down to the local NAPA store and picked up a switch, number sl147. It looks identical to the one currently in place but a note inside the box said it is not compatible with silicon brake fluid and I'm using dot 5. Reading on some of the forums and it said even the oem ones don't last if using dot 5 fluid. Does anyone have any recommendations on a particular switch that is dot 5 compatible
I've been using this one for a few years without any problem and i use DOT 5. '79 FXEF
https://www.jpcycles.com/product/362...light-switches
I use one from Autozone. Lifetime warranty. Has lasted longer than two of Harley's OEM. However, I never ever noticed it says no DOT 5. Interesting. However, they did do a search and said it said, Harley. However, I will need to look up numbers since when I search, their web site shows no Harley Parts.
This is the correct NAPA one. MC14011 Little pricey
AutoZone RB401 is what fits my 04. Mine is 10 years old. Paid $8. for it. It $12 now with a lifetime warranty.
Received 47,832 Likes
Hmmmm ... Dot 5 fluid is not hygroscopic .... which means it doesn't absorb moisture
I also sent a question to the above manufacturer Echlin of the the switch that NAPA sells. And also to the NAPA web site. It's interesting but both answer back that the switch was compatible with any brake fluid. Go figure.
SparkyD (03-14-2020)
Uncle Larry (03-10-2020)
