Secondary Chain Gearing
I hope y'all are doing well.
I have a 79 FLH-80 that I need to replace the trans. drive gear. OEM says 22 teeth and what is on there now is 24 teeth.
I'm also replacing the rear hub sprocket and chain. It has 51 teeth. What gearing would get me better for highways speeds with lower RPMs?
What about the compensator sprocket and the clutch drum sprocket for the primary drive? Any profit of changing those?
Does anyone have any thoughts on this?
Thanks for your help,
gcwil57
gcwil57
rockher_man (08-12-2020)
gcwil57 (08-13-2020)
The following 2 users liked this post by john lee:
gcwil57 (08-13-2020),
TwiZted Biker (08-12-2020)
I like the idea of a 22/47, it puts the ratio at a 3.29:1 at 1:1. And first gear at 2.44 is an 8.03:1 little easier starting off and still maintain clearance for the starter housing... I'm currently running a 3.28:1 in 5th on my Evo and love but it is an OD6 So I still have good cruising gear but I believe at 1:1 I'm still only turning 2850 RPM.. I think I might have to try that 22/47 on my shovel currently it's a 23/51...
