Best fit exhaust pipe
This is a continuation of what is becoming a small can of worms. With he problems I have had with my clutch (other thread) I have ordered the TO bearing and will need to take off the trans cover. While removing the heat shields from the right side I see the the exhaust pipe is broken and partially welded below the junction with the rear cylinder. This is the pipe from both cylinders and has the crossover behind the rear one (#65496-7)0 . I was looking at buying another (#65496-70) but thought I should ask the experts on reputable companies for good quality and fit or companies to avoid.
Or is this salvageable? I could probably braze up a good bit of it. Its quite stable as long as the muffler is connected
Top of joint
Bottom with heat shield on
Top of joint
Sometimes you come accross a Nice system... but it takes perseverance... and you will waste some Money...
My Preference, for an Early FLH
http://www.amraonline.com/BikePics/Jayne's74.jpg
rockher_man (01-21-2021)
I really don't want to buy another exhaust system but yours would have saved me a good bit of time so far.
. So you're says buy an OEM from someone not trust an aftermarket vendor. I don't imagine the originals have HD stamped on them....what are the chinese characters for HD?
The one I am Using is aftermarket, as it is Stainless.. except the cigar muffler is O.E..
I absolutely Dislike the "new true duals" not for me...and the Crossover two into two is much too complicated for my Taste..I looked a very long time for this setup...and got it used from a forum Member who wanted a Two into Two O.E. Setup I had on hand..
Finding Aftermarket stuff that actually Fits is a Giant pain..I do believe that I may yet have a 2 into 1 here someplace for electric start Only... Nothing I want..
Received 4,984 Likes
I have actually found one there yesterday but it had been welded in the same place where mine is broken.
