Beginner Shovel Primary Fluid Question
I apologize if this has already been answered elsewhere. I looked through with the search tool and couldn't find anything that answered my question. Also checked the service manual and couldn't find anything. I just got my first shovel and it has the stock oil lines to the primary. I drained and opened up the primary to clean the clutch plates and am putting it back together now. Even though it has the oiler coming into it, should I toss in some oil just to have some on the chain upon startup? Or do I just make sure to let it idle for a bit and let the oiler do its thing? Sorry if I'm not being clear, I'm trying my best to explain my question. Thanks in advance.
The following 2 users liked this post by Greasychuco:
rockher_man (05-27-2021),
TwiZted Biker (05-30-2021)
Greasychuco (05-26-2021)
Once the clutch discs get oil soaked in the original discs we throw them away -
remove the ball and spring on the steels and stager the install
the discs we only use the red alto USA made and they are reasonable in price
the hub studs if the ditches are deep you need a new hub
when re installing the clutch the discs can not drag on the studs use a W drill bit to over drill the holes if they do - and a ram jet retainer should be used its 10 bucks - it hold the clutch drum from walking out when you pull the lever and that causes no neutral or very hard to find
The following 2 users liked this post by johnjzjz:
Greasychuco (05-26-2021),
Make a suggestion while you are in there put in a Ramjet retainer, takes a lot of the stock shovel clutch stupid out. Keeping the hub from floating in & out and dragging at an idle. Make hitting neutral very easy when adjusted right.
Greasychuco (06-13-2021)
ChrisHall11
Oil Archive (no new posts)
05-29-2014 08:32 AM
