Primary oil question.
Old Apr 5, 2008 | 09:06 AM
Deluxechuck's Avatar
Deluxechuck
Default Primary oil question.
My buddy has an 04' dyna. Gonna change the oil and primary in it for him. My question is, what is the capacity of the primary on an 04'. Pretty sure its a quart, but I don't want to go and spend 50 bucks on a service manuel for him. Just wanting to make sure!
Old Apr 5, 2008 | 09:18 AM
BLade1127's Avatar
BLade1127
Default RE: Primary oil question.
Primary and transmission take a quart. Crankcase takes 2.5 quarts.
Old Apr 5, 2008 | 09:19 AM
Deluxechuck
Thankyou,
Saved me a trip to the stealership where I get to play 20 questions just to get the simple answer.
Old Apr 7, 2008 | 06:32 PM
soup48's Avatar
soup48
On my '04 FXD the manual says to put the fluid in the primary with the bike in a stand-up position till you get the fluid to be near the edge of the hole. The tranny is to put the right amount by using the dipstick. Just add to the full mark.
Old Apr 7, 2008 | 06:53 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
My 02 and 05 Dynas take 20-24 ozs. in the transmission, I put in 22ozs. and call it good. The primary is filled with 26 ozs. in both bikes. There is a caution in both owners manuals about over filling the primary, like rough clutch engagement, incomplete dis-engagement, clutch drag, and/or difficulty in finding neutral at engine idle. Pour in what your mind tells you to do.. Good Luck.
Old Apr 7, 2008 | 08:59 PM
murphdog's Avatar
murphdog
'06 and newer take 1 quart inthe primary, older ones take less. My'03 took 26 oz in the primary.
Frozen Excursion
Jul 31, 2017 06:10 AM
Sikk50
Feb 15, 2012 06:12 PM
cwickgo9
Apr 27, 2008 09:43 PM
JMSporty
May 27, 2007 09:06 PM
k2rmx.rob
Mar 14, 2006 01:37 PM
