Primary oil
Old Jul 29, 2017 | 11:48 PM
Frozen Excursion's Avatar
Frozen Excursion
Default Primary oil
Hey guys,
I apologize in advance if this is a stupid question or something that was already covered.
I have a diesel truck, is rotella t6 5w40 suitable for running in my my primary?
I usually have some T6 left over after an oil change it would be nice if I could use it in my mc without any bad side effects.
Thanks in advance
Dan
Old Jul 30, 2017 | 12:06 AM
bigskyroadglide's Avatar
bigskyroadglide
yes, you can use it with no ill effects, just change it once in a while.
i run straight 40 wt from napa in mine.
i have another bike that i run atf in.
dont over think it, the primary chain and clutch pack and comp needs oil, it does not care about brand.
Old Jul 30, 2017 | 12:10 AM
Frozen Excursion
Thanks a lot.....Just didn't want to do something dumb for the sake of saving a few bucks
Thanks
Dan
Old Jul 30, 2017 | 05:02 AM
gusotto's Avatar
gusotto
Owning a Harley and now saving a few bucks?
A qt. of primary oil won't break the bank.
Check the owners or service manual for correct amount.
I use designated oil that says Primary!
Label that way for a reason.
Even Amsoil has three oils listed.
Primary, engine and transmission.
Old Jul 30, 2017 | 05:22 AM
rgrecco's Avatar
rgrecco
MOBIL1 V-TWIN 20W-50 in all 3 Holes!!!
She runs like a DREAM!
Old Jul 30, 2017 | 06:10 AM
jamesroadking's Avatar
jamesroadking
No. Run a Motorcycle oil that's made to work with the clutch friction discs. Car and diesel engine oils aren't.
Old Jul 30, 2017 | 06:29 AM
skratch's Avatar
skratch
it is if it's jaso rated.
yes, it's fine. been using the non-synthetic rotella in my bikes for nigh on 8 years or so.
Old Jul 30, 2017 | 06:30 AM
Jerry1834's Avatar
Jerry1834
Primary only and look at the manual for the proper amount - just don't put a Qt in and think its correct.....
Old Jul 30, 2017 | 09:47 AM
OldPhat's Avatar
OldPhat
Harley Davidson Formula Plus seems to work well, it's for primaries and transmissions.
John
Old Jul 30, 2017 | 09:53 AM
heavypic's Avatar
heavypic
I've read that someone tested Formula + and discovered it's essentially 50 wt gear oil. I haven't been able to confirm.
If indeed it is 50 wt gear oil, I wouldn't mind finding a suitable substitute available at local auto supply stores. Something that is equally good for the comp and the clutch ('14 RK). It would save me a trip to the dealer for $9/qt Formula +. I bought a jug of Rotella dino 15/40 for the primary but haven't tried it yet.
I use M1 syn 20/50 or 15/50 in the engine and Valvoline Syn 75W/140 gear oil in the tranny. Less dependence on the HD dealership the better...
