Fly wheels
There shouldn't be any- they only change to the flywheels was center of crank pin hole location was moved outward .140", moving the stroke from 3 31/32" to 4 1/4".
Balance factor did change slightly.
3 different weights are in the mix early 80 inch are the same or close to 74 its the grunt thing but they changed them to equal thickness became lighter and then you have S&S equal thickness more lighter again and T&O has stock weight and super heavy = mud bogging i guess
light bike light wheels works - a tug boat needs the wheel barrows weight or your downshifting it all the time on hilly roads
