Stripped the plug hole...
Hey all. Currently working on replacing my rear rocker box gasket and during the process I decided to go ahead and replace the front as well. During teardown of the front, the plug stripped on its way out. The plug is done for, and I'm guessing I should probably get the head fixed.
I can get a plug to thread into it and tighten down, but it wiggles a LOT when you're first threading it in. Once it starts to bottom out, the wiggle goes away and it seems to tighten down alright.
Seeing as I'm pulling the head anyway, I guess I should probably get this taken care of.
Thinking the fix is welding a slug in, drilling and tapping it? I'm against the helicoil route, too many horror stories. And a time-sert kit for this size plug is north of $200. I feel like a machine shop could do the weld/drill/tap for far less than that.
Anyone repaired their head using this method before? If so, what did it run you?
Head is already off and in my hands. I found a local machinist that told me to bring it by tomorrow and he'd let me know my options.
The following 2 users liked this post by BrokenGQ:
Harfar (04-29-2023),
TwiZted Biker (04-21-2023)
Thanks to all of you for the replies.
I called my local dealer to see what machine shop they use, and they directed me to a local guy that is a retired machinist that still works out of his house.
I called the guy and he told me to bring it by tomorrow.
Now to fight this rear head back on...someone didn't do a good job measuring clearances.
Far as the back head going back on be sure the piston is down and not crowned TDC.
Around 30 years ago, I stripped my back plug threads. Back then I lived next door to a guy that owned an auto speed shop. He told me to bring it in, he could fix it while I waited. He said they do a lot of car heads, mostly Fords if I remember right.
They did a Helicoil in no time, lots of grease on the tap, and cleaned often. It is good as new to this day.
A couple years ago, my front gave out. I did it myself using a kit from NAPA, same principal, but used a type of high temp tread cement. Then last year, I was getting pops from the exaust, and front was running hot. I did a compression check, and had around 30 PSI. I pulled the head, and the spark plug was rockiing. The coil broke off with the insert threads.
I took it to a machine shop, they welded it shut, then drilled and tapped a new hole. So far, so good.
I would say in your case, a Helicoil should be fine if the person doing it know what they are doing.
