Shovelhead Head Reinstallation
Old 03-02-2008, 10:19 AM
Rodney's Avatar
Rodney
Rodney is offline
Default RE: Shovelhead Head Reinstallation
I had a set of solids years ago that had a very light spring between the solid conversion and the stock lifter or cam follower they fit inside the cavity and applied slight pressure to the solid conversion.
I really like the looks and ease of adjusting my sifton solids only 2 wrenches to adjust them, others I had took 3 wrenches what a pain they were!
don't forget to have a cloths pin or 2 handy to hold the push rod tubes up out of the way while making adjustments.
Old 03-02-2008, 12:20 PM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
I had a set of those also The spring was not visible As I remember it was inside the lifter body when you set it in place
Old 03-02-2008, 12:40 PM
Rodney's Avatar
Rodney
Rodney is offline
yes inside I think I still have them some where??
Old 11-07-2016, 11:15 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,932 Likes on 3,372 Posts
I know this is an old thread.
Just wanted to say thanx for the info in this thread. It confirmed my first shovelhead lifter adjustment. I thought it was typical to an Evo. My concern was weather it was a hydraulic or solid. It was a hydraulic and I set the pre- load to 28 flats.... Or .145". Thanx again.....
pococj
Shovelhead
11
06-27-2018 02:08 PM
tunaman
Exhaust System Topics
39
04-27-2012 06:15 PM
VA_Grumpy_Biker
01-26-2011 06:38 AM
Bill C
05-08-2010 10:10 PM
HDF Tech
Engine Mechanical Topics
07-03-2005 01:11 AM
Quick Reply: Shovelhead Head Reinstallation
