changing fork seals on a 1974 fxe
Old 08-10-2009, 05:09 PM
tseek555's Avatar
tseek555
tseek555 is offline
Originally Posted by 1unclejojo
Thanks for all the info. I got the bolt out of the bottom of the lower tube.Changed the seals and when to put the bolt back in...wouldn't tighten up all the way(it got tight but would still spin.a little).No oil leaks tho,so is it normal for the bolt to not tighten down all the way,I mean it is tight but could go maybe a quarter turn.But the damper will start to spin,keeping the bolt from being super snug.
Anyway it might all be a practice run.I seen that the previous owner put in a heli coil where one bolt goes for the axle cap.I don't think that it will work.When I had taken off the cap that bolt was loose.Not good when you only have 2 holding it on.
The allen's at the borrom of the slider will spin, just hand tighten, do not use air or elec. to tighten them..
JekyllnHyde
06-12-2019 07:31 PM
lmz5150
EVO
09-17-2018 06:47 AM
maddyv
03-11-2016 01:00 PM
Road Star
08-03-2014 01:02 PM
2K1FLHPI
10-12-2009 11:24 PM
Quick Reply: changing fork seals on a 1974 fxe
