Oil leaks!
Oil leaks!
I have read quite a few posts about shovels leaking regardless of what you do. I just got my late brothers 68 FLH back from my mechanic. He took the top end down, put new rings and gaskets in it, and measured and checked the cylinder walls while it was apart. he said the walls looked good, and didn't need to be machined. I rode the bike home and around town a bit. I noticed oil leaking from the base of the rear cylinder on the right side. what could be causing this? The mechanic also told me that the tranny seal was leaking and may need to be replaced. He said it had been dry for along time (10 years) and may self seal after getting soaked. Is this likely? What type of nightmare am I looking at if I attempt this by myself in a parking lot, with minimal tools, and little mechanical experience?
Also, the base gasket might not be ther leaker - check your tappet box gaskets too. A right side leak gotta be one or the other. Clean the base with brake cleaner and around the tappet box and fire it up - a few minutes should tell ya - tappet box or base gaskets. Make sure its not coming from the oil lines feeding the rocker boxes - remember oil like water will find a way to flow and puddle where you THINK the leak is but its really coming from above...
ShovelheadGreg
ShovelheadGreg
My mechanic already said he would pull the top end off and fix the leak. Is he gonna have to replace the rings? I have also had 3 different people who seem knowledgable ask me about why red silicon was visible at the base gasket, exhaust gasket, and elsewhere. I don't have the answer, but a guy who owns a local shop said the silicone can bulge inside the way it does outside, and then break loose and clog somewhere. Is there a legit reason for putting a bead of silicon on the various gaskets on a harley top end? Is this dependant on the type of gaskets he used? I have been reading about cometic gaskets. They are supposed to create a great seal, and should not be used with any sealant. Any recomendations?
What ever you do to the bike when ever a gasket is changed get newer style metal/silicon gaskets not the older paper ones if you can avoid it . Gasket quality for shovels has taken a serious dump in the last few years most are a step above trash , the metal ones cost more but they don't blow out in 6 months . Rocker box's & cyl. base gaskets are the biggies for leakers . Only place silicon should even be considered is a bit on leaky exhaust flanges and use the Ultra grey not the red stuff , maybe a bit on cheap primary gaskets nowhere else .
