Shovel Pipes
Shovel Pipes
Bought a 1980 FLH Classic 2 weeks ago. I love it, GREAT bike! It is in need of a different set of slip-ons. It currently has a set of real quite small boloney pipes. I'd want them longer and with a "good" sound.Nice deep but not earth quakeing. What would you recommend.
Thanks.
Ragman
Thanks.
Ragman
Received 1,212 Likes
RE: Shovel Pipes
They were stock head pipes with the crossover blocked with a freeze plug brazed in the opening, then the rear head pipe cut in two and the restrictor cut out, and pipe welded back together. The fishtail is straight thru. Setting it up as a 2-into-1 made it sound quite unique.
RE: Shovel Pipes
Unique idea. When the new pipes arrive I'll take a close look and maybe proceed in that direction. I think the cross over pipe maybe cracked, and your set up maybe the answer. Thank you.
Right now I'm working on finding out where an air leak. I get small back fires on idle 'till it warms up. I'm consentrating on the intake O-rings. Replaced the O-ring set-up with wider hose like seals and stock clamps. That improved the situation a lot but still not good enough. I've also been messing with the idle valve. It has a stock Keihn(sp) carb. bought a can ofstartrig fluid to see whats happening.
Would have any other suggestions?
Thanks.
Ragman
Thanks.
Ragman
Received 3,226 Likes
