Exhaust with a Baker 6-4
Dug an old 81 FXEF out of the shed. Looking for an exhaust that will clear a Baker 6-4. I have one and want to put it to this old shovel. Engine, so i've been told is mildly built with S&S carb. No specs available since it was a few years ago. Would like a little muffler in lieu of full drag pipes. Any suggestions on exhaust would be appreciated
custom made may mean awww sh*t i have to do this ,,but you have the chance to weld any brackets on at that time and it fits correctly -- i put a few of those 4 box 6 speeds in theres a few more things ya have to do to make them fit -- the 6th gear is the best advantage over/drive -- i run a belt for a primary a 22 tranny and a 47 rear ... it depends on the h.p./torque of your bike as to what gear it can pull..... i knew a dude with an old panhead he had 24 and a 26 on the tranny -- stock riveted rear 51 -- he SWORE his bike could out run everything -- as it turned out he couldnt out run a regular panhead with 24/23/51 with a bendix carb and a sifton 412 cam---
I tried like hell to make my stock short drags work. They did but by the time i was done it was very restrictive. Good advice here. Have a system made. Had a local guy use the first?? inches of my stock pipes with flanges,then stepped them up to 1 7/8 then to 2". Wrapped them and have been very happy. My trans is offset .250. I would think stock would be even more troublesome??
2" pipes are wayyyyy to big for a stocker even a 80" 2" for maybe over 100" -- i ran 1 3/4 od pipes on my 100" it was good for 147mph 1 7/8" on a 103" is ok -- ya need long pipes for top end -- if your serious ya run unchromed pipes and where ever the purple ring is measure 1" back and cut the pipe --
rockher_man (11-28-2020)
im building a LT1 for my doctor -- 525 hp at the flywheel -- 485 @ the wheels -- headers are 1 3/4 into 3" pipes "X" pipe magnaflow bullets and cherrybomb flowmonsters true ID of 3" 58mm t/b pcm4less computer -- lloyd elliot heads,cam,ect (google that name) had the choice of stepped headers 1 3/4 to 1 7/8 -- theres a word here that 99% dont know -- column inertia thats why i used the 1 3/4 primary's
