clutch issue
Old 07-04-2014, 01:31 PM
pqct01's Avatar
pqct01
pqct01 is offline
Default clutch issue
got a new clutch, new cable... I go by the book.... loosen cable, loosen clutch adjuster lockdown nut.... turn adjuster in until it seats, backout about 1/8 to 1/4 turn, then set the cable until I get about 1/8" freeplay. All seems fine for a bit, then fairly quickly, I loose all tension on the cable, so now there's an inch or so of freeplay. Ive taken it around the block before this happens, and its happened before I get out of the driveway. What could be wrong?
Any insight would be greatly appreciated...
Old 07-04-2014, 01:51 PM
DeJavu's Avatar
DeJavu
DeJavu is offline
It's possible the locking nut was not torqued or loosened up, allowing the adjustment screw to back out. Another, is the new plates had to clean up and settle in, requiring readjusting everything. Check that the throwout bearing is not damaged. Lastly, if the main clutch nut on the trans shaft has loosened the whole clutch would move out on the shaft creating the symptoms you describe.
Good Luck!
Old 07-04-2014, 01:58 PM
pqct01's Avatar
pqct01
pqct01 is offline
Thank you Sir, I appreciate that.... I did replace the throwout bearing also.... forgot to mention earlier.
rnarus
07-08-2018 10:40 PM
Codyyy
EVO
04-05-2015 06:37 AM
bradleys
08-14-2014 08:18 AM
hoethree
07-07-2010 08:26 PM
geargrinder
07-10-2009 09:41 AM
Quick Reply: clutch issue
