Handlebar wiring help????
Old Mar 28, 2012 | 06:50 PM
WoodrowWillson's Avatar
WoodrowWillson
Default Handlebar wiring help????
What is the best way for me to go about running the wiring inside my handlebars? I have 12" Road 6 Custome handlebars.
Thanks
Old Mar 28, 2012 | 06:59 PM
ryderbiker's Avatar
ryderbiker
I used dog tag chain tied to a bootlace. I wrap piece of electrical tape around the wires and tie the end of the bootlace to the tape. Then I slide the mesh wire sheath up past the wires and tape it tight enough that the sheath won't pull back over the wires. The chain will fall through the bars pretty easy. Once it's through you can pull on the boot lace. Some people use lube but I didn't need to. Hope this helped.
Old Mar 28, 2012 | 07:45 PM
pontiac69's Avatar
pontiac69
i have similar bars. i used a string. i tied a nut to one end for weight, inserted the nut on the bar end hole and turned the bars till it came out the bottom. then with the mesh still attatched to the wires i straggered the pins and then using electrical tape i wrapped the string to the mesh and wires for about 6-8". make sure you stagger the pins. i will be hard to make the sharp turns without staggering the pins. Just take your time. i bent a few pins back pulling the wires through on the 1st time. The second time went much smoother since i staggered the pins.
Old Mar 28, 2012 | 08:38 PM
R_W_B's Avatar
R_W_B
Originally Posted by John_KMSMC
What is the best way for me to go about running the wiring inside my handlebars? I have 12" Road 6 Custome handlebars. Thanks
I use a shop vac to suck a string in. Takes about 1 second after you tape off the other holes. I put TBars on which are the hardest to get past the 90* turn so I only pulled 4 to 6 wires at a time, went smooth then.
I made a video back when I did it.
http://www.youtube.com/watch?v=-vkoq6kLlqw
Old Mar 29, 2012 | 07:22 AM
8541hog's Avatar
8541hog
Originally Posted by pontiac69
i have similar bars. i used a string. i tied a nut to one end for weight, inserted the nut on the bar end hole and turned the bars till it came out the bottom. then with the mesh still attatched to the wires i straggered the pins and then using electrical tape i wrapped the string to the mess and wires for about 6-8". make sure you stagger the pins. i will be hard to make the sharp turns without staggering the pins. Just take your time. i bent a few pins back pulling the wires through on the 1st time. The second time went much smoother since i staggered the pins.
That is the quickest and easiest way to go.
Shop vac is great for pvc conduit, but more work that necessary for bars.
Old Mar 29, 2012 | 08:03 AM
R_W_B's Avatar
R_W_B
I would have to agree on bars that are shaped to accomodate that. 8541hog is one who gave me advice the first time I did bars. I have done some electrician work in my lifetime so by nature I always grab the shop vac. Works great for cleaning up gasket residue also after scraping.
I can't remember if I said to stagger the wires in my video but YES that is key. You must do that. I have gotten to where I purposely used masking tape instead of electrical tape though since electrical tape (even when on for a short time) leaves a messy residue. Masking tape leaves none but holds good.
Some bars are more of a problem than others just depends on the internal structure of the weld. If you run into a problem, back off and try again, you don't want to scrap the insulation off or you've got a mess then. Anyhow happy wire pulling.
Old Mar 29, 2012 | 08:21 AM
jaysledge's Avatar
jaysledge
Plumbers chain and I used baby powder to coat the sheath, since mine were covered in the plastic. Tape the chain to about 6 - 8" of the sheathing and go slow. About a two beer job.
Old Mar 30, 2012 | 03:27 PM
WoodrowWillson
Okmso where do I start with the wires? Do I need special tools to pull the plugs off? I don't want to cause more damage then I have to.
Thanks a lot for the help fellas
Does anyone know of a video of the whole job?
Old Mar 30, 2012 | 03:45 PM
jaysledge's Avatar
jaysledge
I used a small precision screwdriver to get the old wires out of the connectors. I think muddog or go to br custom bars they have some videos on installing wires.
Old Mar 30, 2012 | 04:20 PM
R_W_B's Avatar
R_W_B
The signal 3 wire AMP and the larger Molex connectors have a tab on them to pull the male and female apart. (some models have Deutsch instead of Molex).
After you get them apart some Molex's have two side slots to pry out the locking plate with a small flat screwdriver. Others have two center located small square holes. I grab those kind with needle nose pliers and pull outward. It will snap up bout a 1/4" to 3/8"
BEFORE removing the wires and socket pins WRITE DOWN the wire colors and pin locations on some paper and don't loose it.
To remove the AMP pins I've had better luck with a Bobby pin. I filed it flat a bit on the end. I bend it in a 90* angle so I can grip it and twist it when I feel it grab the tab inside the connector. On the AMPs push the Bobby pin into the inside row of holes (not the outside those are the socket holes). It should go in bout a 1/4" of more and keep it snug towards the pin side until you feel it hit the tab. Then twist the bobby pin. It takes few tries. Mudd has an excellent video on Youtube on these.
The Molex pins I have better luck with them using a heavy paper clip bent the same way. Other wise the procedure is very similar.
