J&S bottle jack failure
Old 10-09-2015, 04:12 AM
Mello03's Avatar
Mello03
Mello03 is offline
Default J&S bottle jack failure
Guys I'm looking for a solution here. I went out to ride last night and the bottle jack on my J&S was dead. Now my bike is suspended with a dead jack. I called J&S (closed of course) and I'm hoping they'll send me another, but I really would like to ride before next week. I can guarantee they won't overnight me a cheap China made bottle jack for Saturday delivery. Where can I find another bottle jack with a base big enough to drill holes through? Also, I'm assuming I can remove the bottle jack while 900 lbs and 27k dollars is suspended a foot off the ground? Bought this thing in May and the jack didn't even make it 5 months I'll go buy a jack, but want a backup in case this happens again.
Any thoughts?
Old 10-09-2015, 05:06 AM
heybaylor's Avatar
heybaylor
heybaylor is offline
Have you checked the fluid level ?
Firebike32 (03-09-2024)
Old 10-09-2015, 05:24 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
I'd pull the bottle jack out of the lift and fill it with oil, then bleed it. Re-install and get that bike off the lift. That way you can deal with the bottle jack later.
Old 10-09-2015, 05:37 AM
Next In Line's Avatar
Next In Line
Next In Line is offline
Odd how the jack will not go down. Usually a bad jack will not go up.
Are you sure that the safety is not engaged?
Old 10-09-2015, 06:36 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
Try to get the air out of the system by just pushing down on the side of the rubber plug that's on the side of the jack with your fingernail then pump on the jack and repeat the bleeding process another time or two.
Old 10-09-2015, 07:22 AM
Mello03's Avatar
Mello03
Mello03 is offline
Thanks guys I will try what you suggested. Yeah this thing will not go up enough to get the safety stops out of the slots. So basically my bike is stuck with the safety stops in place.
I haven't checked the oil but I'll do it when I get home.
Old 10-09-2015, 09:53 AM
IzzoQuazzo's Avatar
IzzoQuazzo
IzzoQuazzo is offline
Retired Admin
Received 9,039 Likes on 3,711 Posts
Call J&S. They had a bad batch of bottles some time back. They WILL overnight one to you. They stand behind their product. They did it for me and others.
The following 2 users liked this post by IzzoQuazzo:
dlwilson72 (03-03-2024), JimmyDee (11-25-2017)
Old 10-09-2015, 11:21 AM
Campy Roadie
Put 4 or 5 quarters in the cup where the jack ram goes. That might shim you up a little higher.
Super Glidester (12-05-2017)
Old 10-09-2015, 12:39 PM
wwiiavfan's Avatar
wwiiavfan
wwiiavfan is offline
Received 1,107 Likes on 490 Posts
Rent, (or better yet, borrow from a bud) an engine hoist. Remove seat and tour pack, thread a nylon strap around the rear bag guards, and lift her up. That's how I used to get mine onto a welded cart frame for off season storage.
The following 2 users liked this post by wwiiavfan:
04ctd (02-10-2018), GTrog (06-07-2019)
Old 10-09-2015, 12:52 PM
vizcarmb's Avatar
vizcarmb
vizcarmb is offline
Go to harbor freight and buy an bottle jack. When My yellow jack failed, I just bought another one and modified it to fit the jack. It just took me longer to jack the bike up with the new bottle jack
Quick Reply: J&S bottle jack failure
