M8
M8
Got the M8 and have 3500 miles on it and everything been good the only thing I was curious about is my fan is constantly running in slow traffic or when I ever I stop when the temps are above 60 runs ok no issues does anybody else have there fan going on all the time it runs for about 15 seconds when I shut the bike off I have the 107 ultra limited
Honestly, I'm enjoying the ride/music so much, I don't even notice. I can only tell it's on while sitting at a light when I, purposely, turn the music down out of politeness for those right beside me. If it's in the driveway/parked and running when I return from a ride, I can hear it because the music is down. I'd imagine you are fine and this is a benefit of buying a "wet" head ....to help keep the temps down
RTFM Fellas !
There is feature .. not sure what it's called where you can shut one cylinder off in "hot" conditions. The cylinder the acts as an air pump to cool the engine. I'm at work but will look it up later. Not sure for all m8 models but 100 percent sure for 16 and 17 ultras..check you manual.
RTFM Fellas !
RTFM Fellas !
As for the rear cylinder acting like a air pump ....check your manual
WOW....is RTFM....read the F'n manaul? If so, you may need to read it too. He's not talking about cylinder deactivation....he's talking about the actual fan on "wet heads" The cylinder deactivation just shuts down the rear cylinder so that it isn't giving off heat. I'm no mechanic....but it doesn't act like an air pump ---it just shuts down so it's not pushing heat on your leg. My 13 SG had the same feature---it's not new. But he's talking about the fan...
