XL1200C tire wear
Old 04-30-2017, 10:22 AM
harleyrider4300's Avatar
harleyrider4300
harleyrider4300 is offline
Default XL1200C tire wear
I am a longtime Harley rider. Most of my time has been on touring bikes. I regularly check my tire pressure and follow mfr recommendations on pressure.
In touring bikes with stock dunlops I got the following mileage:
07 and below. 20 K for a front, 10 K for a rear
09 and up. 25 K for front, 18 k for rear
I bought a new 2016 1200C with stock Michelin tires in Oct 2016
I have almost 7K on it so far, and I am astonished at finding my front tire at 4/32, and my rear at 7/32. Just the opposite of what my experience has been on other models.
Is this normal on sportsters
Old 04-30-2017, 07:18 PM
Bluesrider.df's Avatar
Bluesrider.df
Bluesrider.df is offline
Received 1,663 Likes on 936 Posts
I got about 10K on factory Dunlops on my '07 XL1200C. I now have the American Elite Dunlops, and they seem to be wearing better.
Old 04-30-2017, 09:09 PM
Guzzi's Avatar
Guzzi
Guzzi is offline
My 2014 Custom the rear was worn by 7000 and the front was mid life
Old 04-30-2017, 10:03 PM
BlackBettyXLC's Avatar
BlackBettyXLC
BlackBettyXLC is offline
As others have mentioned, you are experiencing fairly normal wear for Sportster tires. I have an 07 1200C and I have a Michelin Commander II up front and it's about half way through its life at ~6k mi. I have the stock rear Dunlop on and it's around 12k mi and I'm replacing it this week.
Old 05-01-2017, 07:32 AM
harleyrider4300
I must have said it wrong. My front tire is 1/32 away from me replacing it (I replace my tires at 3/32 remaining). But my rear is not quite 1/2 way through its life. This is backwards of what I have experienced. Normally I go through two rear tires for every front
Old 05-01-2017, 11:05 AM
Bluesrider.df
You need to do longer wheelies.
Old 05-01-2017, 03:08 PM
cHarley's Avatar
cHarley
cHarley is offline
Your front tire excessive wear issue is normal and due to the skinny front tire.
I got 8-9K miles out of my first 2 21" front tires. When the second tire wore out, I replaced the 21" wheel with a 19" as is standard on the non C model Sporties. Over 100,000 miles now on the Sporty and I routinely get 22-24K miles on a front tire.
Old 05-01-2017, 03:13 PM
cHarley's Avatar
cHarley
cHarley is offline
Does your 2014 Custom run the skinny 21" front tire/wheel being discussed here???
Old 05-01-2017, 03:16 PM
Bluesrider.df
Did you have to replace other parts when you replaced the wheel?
Old 05-01-2017, 03:27 PM
harleyrider4300
I do not have the skinny front tire. I have a 2016 XL1200 Custom.
Quick Reply: XL1200C tire wear
