fat tire conversion for dyna
Old 07-20-2017, 10:03 PM
Canyonrun's Avatar
Canyonrun
Canyonrun is offline
Stage IV
Default fat tire conversion for dyna
Will a 2016 Dyna wide glide rear wheel work on the front for a fat tire conversion
Old 07-20-2017, 10:23 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
Nope.
Old 07-20-2017, 10:24 PM
billib1954's Avatar
billib1954
billib1954 is offline
Now why would you want to do that?
Old 07-20-2017, 11:25 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
Anything is possible with enough money and effort. Easier to just lace up a new rim. I've got a 17x4.5 on the front of my wide glide. Stock hub, Buchanan's spokes, Excel rim.
Old 07-21-2017, 08:20 AM
archergodwin's Avatar
archergodwin
archergodwin is offline
Won't have room between the forks on a midglide front end tho.
Old 07-21-2017, 12:38 PM
Chicago Ken's Avatar
Chicago Ken
Chicago Ken is online now
Look into a Fat Bob front end.
Old 07-21-2017, 01:17 PM
fskitch's Avatar
fskitch
fskitch is offline
I think OP's working w a WG. No need for a FB front unless he wants to reduce rake. My statement is for 06 and up dyna's just to be clear.
Old 07-21-2017, 01:45 PM
blueangel73's Avatar
blueangel73
blueangel73 is offline
If the OP is working with a Wide Glide and already has the extra rear wheel, then he is pretty much setup for the change. Use the front hub and lace it to the rear rim with the rear spokes. The front and rear spoke to hub geometry is the same, it's the brake disk and rear sprocket mountings that are different. Then all the OP would need to do is locate a front tire to fit the rim.
Old 10-29-2017, 08:57 PM
Michaelcarbonaro35@gmail.com's Avatar
Michaelcarbonaro35@gmail.com is offline
4th Gear
Can I see pictures of your bike, I'm about to do the same to mine, but I wanna compare the look of a few different sizes before I do
Old 10-29-2017, 09:05 PM
cggorman's Avatar
cggorman
cggorman is offline
I'm still working on it so this is the best I've got right now... 180/70-16 in back and 150/80-17 in front. Slightly taller than stock ride height.
Quick Reply: fat tire conversion for dyna
