Up shifting
That would be my question also. I've noticed a difference in what type of Trans Fluid I run, so now I stick to Redline Shockproof or Amsoil Severe Gear.
It is hydraulic and I have double checks the fluid levels. It feels like it’s not disengaging enough while shifting. While stopped the clutch feels like it’s working great. I have to let the clutch out half way before it starts to catch.
New problem or just recent issues?
Keeping it simple initially is good advice.
So here’s another simple one;
Got new boots?
Which shift method do you use, toe up or heal down when upshifting? On my EG, I prefer toe up, but heal down yields a considerably smoother shift. When using toe up, on occasion I’ll have my boot under the shifter getting ready to pull, but there is enough upward pressure to pop it out of gear as soon as I start to pull the lever in. I guess it’s a brain/hand/lifting the foot to shift timing issue for me (all of which are becoming a challenge for me because according to some...I have no brain).
Got new boots?
How many miles? Stored inside or outside? How do you wash it, high pressure car wand, garden hose, or some other way?
Around 25,000 miles the ball joints at each end of the shift rod are prone to failure. They might be binding shortly before failure. Replacing the ball joints with Heim joints (spherical rod ends) is a popular upgrade.
Storage and washing, parked outside or washing with high force water, the pivot rod on which the heel and toe shifter arms are mounted can have dry bushings also causing extra force to be needed for a clean shift.
Finally, check the shift arms at both ends of the linkage for tightness on their respective shafts, especially the one on the transmission.. If they have never been tightened, I can almost guaranty there will be some slop on the shaft. Tighten and lube everything and get back with us.
