What touque cam to get
Ok I知 looking at getting a cam for my 17 custom, Now what I知 looking for is something that is bolt in with the stock lifters and head, to enhance the touque performance of the stock engine.
Im looking at getting my scoot pull better around the 3-5 thou rev range as I all ready have rush pipes and a powervision tuner, with a k&n air element , so breatheing is taken care of.
Any suggestions would be great from someone that has all ready gone done this path.
Thanks in advance
WiZ
Thanks in advance
WiZ
Take a look and read through Hammer Performance cam information.
It sounds like you would like their JackHammer 570 cams-
Jackhammer 570 - Bolt-in grind for 2004-up 1200 models.
Designed to give a boost in mid range and top end over the factory "W" cams with no loss in bottom end power.
Ideal for the stock 9.7:1 compression ratio but can be used up to 10:1 with careful tuning.
http://www.hammerperf.com/xlvalvetrain.shtml
Wizardofaus (04-26-2018)
+1 on the Hammer 570's if that's all you're going to do. As you can see though, you're not going to get any BIG gains with cams alone. IMO, cams and headwork go hand-in-hand and as you can see above, doing cams only isn't going to make a huge difference. Credit though to Aaron at Hammer for squeezing every last once out of a stock motor with the 570's.
FYI, the stock W cams are already pretty darn good if the rest of the motor is going to stay stock.
Received 2,189 Likes
Madnss (05-02-2018)
i don't think so... this is what you have to pick from with HD unless they have a secret stash
from se 2018 catalouge
The following 2 users liked this post by Scuba10jdl:
apache snow (04-27-2018),
Wizardofaus (05-02-2018)
