Engine Oil Capacity?
For some time I have tried to find a satisfactory answer to my question about oil capacity. I have a 2011 Road King Classic and while the manual states it takes 4 quarts of oil with a filter change, I have never been able to get near 4 quarts of oil out of the engine. What am I doing wrong? I check the oil level often. While both the service and owners manual state to check oil while on the jiffy stand, neither publication says what position the bike needs to be in for an oil change. I have tried both upright and on the jiffy stand with similar results. Just want to make sure I am getting all of the used oil out. Thanks.
Mongo1958 (05-11-2024)
Received 2,526 Likes
The factory "capacity" is probably for a dry engine and dry filter. After that the amount of oil needed for a RE fill is totally dependent on how much oil came out. Typically that seems to be about 3 1/2 quarts but may be a little more or a little less. If you want to be sure you have enough oil on hand to complete the oil change, 4 quarts will be MORE than enough and will leave you with some left over in case you need to add a little later on. The "CAPACITY' of your gas tank is 6 gallons, but no one ever insists on pumping 6 gallons into a tank that only needs 4 1/2 gallons to fill. Same idea with the engine, transmission, and primary case.
A personal technique that makes me FEEL better but probably does little additional benefit: I start the drain (any of the three reservoirs) on the jiffy stand. When the flow is down to a trickle or just drips, I will lean the bike as far to the right as I can comfortably, hold it there briefly (my leg gets tired) and rock it back onto the stand. After 2 or three repeats, no more oil comes out when back on the stand. Put the plugs back in and fill until the dip stick is happy or the visual level is correct. I never know ahead of time how much that will take, but having the factory capacity amount on hand is always more than enough.
My 2014 manual has the same procedure. I have never had to add more than the 3 quarts, the level is about 1/3 to 1/2 way into the checked area on the dip stick. It makes no difference whether on the side stand or upright on a jack.
As mentioned, stop short and check, a pattern will develop, and you will learn what to expect.
One of my trucks states 6 quart capacity, but at change time I drain it all, and put in 5 1/2 quarts and it is up to the full mark. Been doing this for 240,000 miles, same old same old each and every time.
I do about 3 1/2....then ride it and check it later, add a touch if needed.
Followup question for all: how many folks fill up their new filter with oil before installing it on the bike?
Have read tech posts/articles on this elsewhere.....some strongly advise doing it but I rarely see it mentioned anywhere.
