S&S T124 / Dakota Digital Gauges
Anyone here running an S&S 124 in their bagger and using the Dakota Digital Gauges? I'm trying to figure out if the external oil lines are going to interfere with the oil temp sensor being installed in the oil drain hole. Looks to be very close fit....
Thanks
Thanks
I have no experience with Dakota gauges or their required sensors/wiring.
I have a 124" S&S crate engine in my '16 bagger. Three oil lines come out of the engine in the area of the oil drain plug. Two run to the primary side of the oil tank, one uses the plug next to the oil drain plug.
Based on MotoJockey's pic above, the hole he uses is the one used by the oil line kit. The other oil lines are right above that plug. It's close in there, but the oil lines in no way impede my oil drain plug.
I don't suspect they would affect that sensor or sensor wire IF it could be installed in the oil drain plug.
I have another bike on my lift right now, but will get down on the floor and try to take a pic of this area on my bike and ad the pic a little later...
MotoJockey (05-21-2024)
Gotta feed the Great Danes first.... When combined 300lbs of Great Dane get hungry, HD pics come in second...
They won't let me in the shop until they get fed....
The following 4 users liked this post by hattitude:
Thanks
Obviously the OP doesn't need it, as he already has the oil lines, but.....
As promised, here is the pic. This is for others who may read this thread and wonder what the big deal is...
To the OP, as I was trying to get a good pic, I realized it's a little tighter than I remembered in that space. Certainly no problem for a drain plug, but a 1 1/2" sensor protruding from the oil drain...?That's a tough call.... I wouldn't gamble $1200 dollars on wondering about sensor fitment...
If your heart is set on the Dakota gauge package, ask them to sell you just a replacement sensor. Then there would be no guess work.
It will be much cheaper should it NOT fit, and you would have a spare sensor on hand if it DID fit... just a thought...
Forgive the dirt... I just got back from a trip, and the bagger is next up for full service and a detail. I always give my bikes a good cleaning before I do the service...
